跳转到主内容
iPad Mini4 Wi-Fi版型号A1538指南 。iPad Mini3的后继版本iPad Mini4 发布于2015年9月9日。
97 个问题 查看全部
Why doesn’t Siri work after screen replacement?
I just replaced my iPad mini 4 screen and the home button works fine and so do all the other buttons, but when I try to use Siri it doesnt come up on the screen. Nothing happens. I’ve tried hey Siri, the Siri button on assistive touch, ad I’ve triple checked all the settings that has to do with Siri. I’ve also reset settings then reset my whole iPad without restoring to a backup. Any suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I’m having the same problem. I bought an aftermarket lcd / digitizer and installed it. The first thing I noticed was, it would no longer sleep either with the sleep button or by closing the Smart Cover. I later learned that this lcd /digitizer did not come with a sleep/wake sensor installed and now I see that I can’t access Siri as well. Have ordered a new sleep/wake sensor $5 and will see if Siri works after install.
完成的
添加一条评论
1个答案
已选择的解决方案
There are two cameras on the mini 4, both located around the rear camera (see step 29 of this guide). You may have damaged one of the flexes while removing the screen assembly. It could also be caused by some dust or lint clogging up the microphone holes in the housing so you should inspect those and clean as required.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Garrett Driskill 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 1,168
