跳转到主内容
修复你的物品
维修的权力
商店
My hisense ruko screen has cracks going through it when I turn it on?
Screen when off doesn’t have any cracks on it but once I turn it on it has a huge crack on it? The cat knocked the tv over on my Gatorade bottle and onto me (who was cleaning right next to the tv). What part is actually broken on it? And where can I get it and how do I personally fix it? Cause I can’t afford to just take it in.... the model number is 32h4c
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
打开所有标签
Mac的RAM升级套装
购买套装
所有选项卡都有足够的 RAM
购买套装
3个回答
已选择的解决方案
@thatamazinchick post some images of what your screen displays, that way we can see what you see. Use this guide 在已经存在的问题里加入图片 for that. If it is a cracked LCD, it will be difficult to repair. Panels are hard to find and will cost most of the times more than a new TV. If you do need a new panel remove the back from your TV and you should find a manufacturers label on the panel. Give us those numbers so we know who made your panel etc. Or you can try to find a TV like yours with issues other than the display and harvest it from that.
这个答案有帮助吗?
得分 2
添加一条评论
Hi @jamescothran ,
The screen has been cracked
If it is a new TV straight out of the box, check the user manual or the warranty statement that should be included with the TV as to what to do to make a claim for a manufacturer’s warranty repair or replacement.
Depending on your location it may say to contact the retailer or the manufacturer’s customer service section about a manufacturer’s warranty repair or replacement
The screen cannot be repaired it has to be replaced (or the TV has to be replaced)
这个答案有帮助吗?
得分 1
添加一条评论
just got my tv and took it out the box and plug it in and this is the screen I get
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Samantha Feldhaus 将永远感激不已
浏览统计数据:
过去的24小时: 4
过去的7天: 9
过去的30天: 58
总计 1,250
