跳转到主内容
How do I connect my device to the internet?
I want to connect to the internet, but I'm not sure how to do so wirelessly.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
You connect your Amazon Echo Dot through the Alexa app! Go to settings, select your device, and select set up wifi! I am attaching a link which will give more help on connecting your device to the web.
https://www.amazon.com/gp/help/customer/...
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Connect echo dot device to Wi-Fi network:
Go to Settings option from the left navigational panel.
Select your device and after select update Wi-Fi.
Try to press and hold action button when the light ring changes to an orange and select Wi-Fi network, enter the password.
Also, Make sure enter password is right to connect to the network.
这个答案有帮助吗?
得分 1
添加一条评论
If you want to connect echo dot to a Wi-Fi network, follow the instructions in the Alexa app. Most important thing that is echo dot connects to dual-band Wi-Fi (2.4 GHz/ 5 GHz) networks that use the 802.11a / b / g / n standard. Echo Dot does not connect to ad-hoc (or peer-to-peer) networks.
To learn more, go to '''Connect Echo Dot to Wi-Fi'''
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cassidy O'Connor 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 63
总计 6,652
