跳转到主内容
在2015年3月发布,于2015年4月10日开放购买,Galaxy S6 Edge是Samsung最新的旗舰智能手机的曲面屏幕版。
237 个问题 查看全部
Dropped in water, won't boot.
After dropping in water, left powered off. Disassembled and cleaned with alcohol. Replaced charging daughterboard because I thought the USB connector was damaged. Replaced battery.
When I plug phone into charger the display comes up, battery goes to 100%.
I can't turn the phone on by holding the power button. The phone does not respond to wireless charging pad.
Is motherboard damaged, how can it tell if so?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
Here take a look at this question.
Good luck!
What to do if dropped in water
这个答案有帮助吗?
得分 1
添加一条评论
Your battery reading 100% at all times MAY be a bad battery. if it is shorted inside, it will ALWAYS read 100%.
Water Itself is not damaging to the board. water in it's purest form is non-conductive. the actual problem is the minerals in the water. (Iron, Calcium, Sodium, Lime) These are conductive and cause damage. unfortunately, they have a much higher boiling temperature than water, so when the water evaporates, these minerals are left on the motherboard. Rice doesnt actually help the damage, but rather speeds up the drying porcess. If the phone functions WITH the rice treatment, it would have worked without the rice treatment.
as a water damage repair, it still is only 50/50 as to whether or not you can get the device up and running. follow the next steps, andyou may have a functional device.
1) Isopropyl: Take a 99% rubbing alcohal, also known as Isopropyl, and a toothbrush. (New, as it can not be previously contaminated by conductive materials such as saliva, or tap water) soak the board in the isopropyl, and scrub diligently. make sure not to be terribly rough on the board, but still use a heavy handr
Check to see if board works
2) DeOxit (Electronics cleaner): I have used many brands, but DeOxit is the the one i have had the most success for, so i suggest this brand. others may work, and it is only a personal preference. spray the cleaner onto the board, and seal in a tupperware container. let sit for an hour, then re-soak with isopropyl to dilute any lifted dirts, and scrub with the tooth brush. Essentially, after the DeOxit has sat, Repeat step one.
3) Sonic Wash: This is implying you have access to the tool required. usually need a repair shop environment to have one The sonic wash is a tool, usually cosing between 300$-500$. fill it with distilled water and a liquid electronics cleaning solution. this pulses the cleaner underneath components where a brush can not reach. though this is the most successful procedure, it is also the most expensive of the three.
i hope this helps, and if it does, please accept the answer.
4) After all of these procedures, if any funtions aren't working, try replacing the modular component that the function is related to. (Antenna's for signal, Charge port for charging, Camera for camera function, ETC.)
Anything further than this will be a board level failure.
这个答案有帮助吗?
得分 1
添加一条评论
My previous answer is the Do's for water damage. this next response is personalized for your issue specifically.
if your battery is reading 100% at all times MAY be a bad battery. if it is shorted inside, it will ALWAYS read 100%.
the power button on the S6 models is pressure seated. meaning the screws need to be in place to function. if the alignment of the button flex, is not aligned with the board, then you may have a disconnect. to test this, remove the back housing, (with the power button) and short out the two pins that the flex connects to on the mother board for 3-5 seconds. if your device boots, there is no problem with the board. if it does not, then the board is having issues.
The power button may be a cold circuit. use the continuity setting on a multimeter, and hit the pins on the power button flex with the two leads. If done correctly, when you press the power button in, the multimeter should beep. if it does not beep, then the power button needs to be replaced.
这个答案有帮助吗?
得分 1
1条评论:
Good idea, thanks
完成的
添加一条评论
There might be some issues after you replaced the charging board, just to be save, get a sealable container, fill it with rice, and sit your phone in it, and seal it. Check back in 4-6 hours just to make sure all water is gone.
这个答案有帮助吗?
得分 -3
3条评论:
No Save the rice. Rice doesn't help and this is commonly mentioned it does not help on iFixit I'll be back in a minute.
完成的
It has been months since I took this back on. I am sure it is sufficiently dry but good suggestion.
完成的
even though water damage was a while ago it can come back and ruin everything. Rice does not help. Reason why is it leaves residue from when it was wet. that residue needs to be removed from the motherboard or else it may short circuit at an unknown time!
完成的
添加一条评论
添加你的答案
Kevin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 4,842
