跳转到主内容
The OontZ Angle 3 is a high quality, lightweight speaker made by Cambridge SoundWorks.
17 个问题 查看全部
Why won't the Oontz Angle 3 speaker connect with PC Bluetooth?
The connection worked previously, I have no idea what has changed.
The PC sees the speaker, but the speaker doesn't play.
I tested the PC with AUX cable which works, I am also able to connect the speaker through Bluetooth on my phone.
I have checked all my PC settings and have no idea what else to look.
Help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
This happened to me, too, recently. Just after updating my PC, the Oontz Angle 3 would only be recognized as "Bluetooth Headset" and would fail to connect.
I have obviously removed the Oontz Angle Device 3 and tried to reconnect it.
I have also deleted/reinstalled any/all Bluetooth drivers on my computer.
The Oontz connects perfectly well on my iPhone, however.
What is going on?
完成的
I still don't know the reason, but it worked for me when I uninstaled the speaker and installed it again. It happened to me a few times the Bluetooth connection didn't work without this "manual reset". So, go to devices, installations, and remove and then again add the speaker. I hope this helps you too!
完成的
添加一条评论
1个答案
In my case, the computer was able to identify the speaker but it would not connect, giving a message that the device was not responding. After trying a number of other possible fixes, such as deleting it from the computer memory, rebooting the computer, turning off the firewall, I turned off the speaker and even disconnected it from the USB cable. I let it sit, powered down, for about 3 minutes, and then restarted the process. It connected without a problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kristina Bogataj 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 17
总计 3,347
