跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1505 个问题 查看全部
Home and power buttom doesn't work
Hi, I just tried to replace my back case and battery at the same time. After I reassemble the iPhone, both the home and power buttom don't work. But the iphone start normally. And I check all the connectors are connect correctly. Please advise. Thank you
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
3个回答
已选择的解决方案
Before you start replacing all the parts, try loosening the screws on the power button-sometimes they are overtightened and the button has not "play" in it to make/break connection.
Take a look at the back of front display panel and you'll see the 2 gold prongs of the home button-they often get flattened when you open the phone, lift them up gently with a flathead screw driver. They make contact with top of dock connector... not connector 2. Check that area for any damage
这个答案有帮助吗?
按维修分数 2
添加一条评论
I would hazard a guess at the connectors, the home button is #2 connector if my memory serves me right, I would hazard a guess at the home button being #5 as U can't think of anywhere else that the power button would connect to the logic board, unless of course it's the camera connection?
I would play it safe and strip it apart and just make sure they are connected properly.
这个答案有帮助吗?
按维修分数 0
添加一条评论
you would have to check with your back case, is it a genuine one or the after market china copies, as some of them are faulty, you should take the audio flex from your original housing and switch it with the one in the housing you wish to use, and the home flex, u check for connectivity with a multimeter as your pressing it and depressing it, if its all good there, then it's your system connector that needs replacing. 3gs home flex can be used in a 3g, the pins are longer too.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Louis 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,607
