I forget My Vivitar tablet password
Dear sir
i forget my tablet password , so kindly let me know how i reset my password
Regards
RAVINDER JHAJJ
@ravinderjhajj a forgotten password will require a factory reset. This will delete all your files like music, pictures etc. If you have not backed those up prior, they will be lost by this.
这个答案有帮助吗?
Thanks for your suggestion , i am trying to do your method , but its not working .. kindly let me know any other way to fix up my problem ....
En español lo pueden traducir
Does anyone know how to retrieve my password to my vivitar ear buds. They're just cheap ear buds. It does give me the forgot password options
Power off the device. And then hold down the Volume – and the Power button at the same time until the large android shows up in the center of the screen. You will then be able to use the Volume – sign to go down the menu to choose “Wipe data/Factory reset”. Once you have done that use the Volume + sign to go back up the menu and choose “Reboot system now”. Hope that helps!
这个答案有帮助吗?
This worked for Vivitar tablet with FCC ID: QD4WA168
Hold vol - and power while device is off then follow the following instructions stated above
Just tried and it worked
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 17
总计 4,482
