跳转到主内容
Repair guides and support for tablets manufactured by Vivitar.
13 个问题 查看全部
I forget My Vivitar tablet password
Dear sir
i forget my tablet password , so kindly let me know how i reset my password
Regards
RAVINDER JHAJJ
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
已选择的解决方案
@ravinderjhajj a forgotten password will require a factory reset. This will delete all your files like music, pictures etc. If you have not backed those up prior, they will be lost by this.
  • The tablet must be powered off.
  • Hold down Volume + button and Power button at same time.
  • When screen comes on let go of the Power button only.
  • When the large Android shows on screen let go of Volume + button.
  • Use Volume – button to scroll to Wipe Data/ Factory Reset
  • Tap Power button to select.
  • Use Volume – button to scroll to Yes.
  • Tap Power button to select Reboot System Now.
这个答案有帮助吗?
得分 3
3条评论:
Thanks for your suggestion , i am trying to do your method , but its not working .. kindly let me know any other way to fix up my problem ....
完成的
En español lo pueden traducir
完成的
Does anyone know how to retrieve my password to my vivitar ear buds. They're just cheap ear buds. It does give me the forgot password options
完成的
添加一条评论
Power off the device. And then hold down the Volume – and the Power button at the same time until the large android shows up in the center of the screen. You will then be able to use the Volume – sign to go down the menu to choose “Wipe data/Factory reset”. Once you have done that use the Volume + sign to go back up the menu and choose “Reboot system now”. Hope that helps!
这个答案有帮助吗?
得分 1
1条评论:
This worked for Vivitar tablet with FCC ID: QD4WA168
完成的
添加一条评论
i hva e camelio by vivitar tablet .. and its not working
这个答案有帮助吗?
得分 0
添加一条评论
Hold vol - and power while device is off then follow the following instructions stated above
Just tried and it worked
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
RAVINDER JHAJJ 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 21
总计 4,335
