跳转到主内容
加入维修社区 - 创建账户
Support for percolators manufactured by Farberware.
What happens if I accidentally run percolator wo water?
what happens if I accidently run percolator wo water?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
I accidentally ran my machine without water. Is it repairable or shot?
完成的
The result is a burned out heating element. If you have some technical skills and parts access it should not be a tough fix. I could not locate the parts needed. Thus, I ended up scrapping the old percolator saving all removable parts and bought a second hand Farberware on Ebay for about $30. That price was a lot cheaper than the time needed to chase the parts and make the fix. I love this percolator and use it every day, but I now make certain that I do not plug it in until I have put water into it.
完成的
添加一条评论
6个答案
已选择的解决方案
1. No coffee
2. Basically nothing. Ever noticed that if it is left plugged in and gets cold it starts to re-perk? The thermostat shuts it off once it gets to hot, just like it does when you run out of coffee.
这个答案有帮助吗?
得分 3
3条评论:
Not true! I just did this by accident (i.e., tried to make coffee and forgot to add the water) and my Faberware percolator had a burning smell about 3-5 minutes into it, so I immediately unplugged the machine, having realized that I forgot to add water, and let it cool down, but unfotunately the coffee maker no longer works :(
完成的
I don't know about the newer ones. Maybe they aren't built as well. Mine lasted about 40 years and ran dry many, many times with no problems.
完成的
Same with me. It ran only for a minute and I smelled it burning. Mine still works but the stand pipe has turned black and smells burnt after making several cups of coffee. I was wondering if it's safe to drink coffee out of it now?
完成的
添加一条评论
It will ruin your coffee maker! :(
I just did this by accident (i.e., tried to make coffee and forgot to add the water) and my Faberware percolator had a burning smell about 3-5 minutes into it, so I immediately unplugged the machine, having realized that I forgot to add water, and let it cool down, but unfortunately the coffee maker no longer works so I just threw it away :(
这个答案有帮助吗?
得分 1
添加一条评论
1 of 2 things most likely.
either nothing happens and it gets hot, or possible much more likely it would burn up and start to malfunction or stop working entirely
这个答案有帮助吗?
得分 0
1条评论:
Possibly has a high limit switch that opens circuit so no more heat. Could be able to re-set or need replacement depending on design.
完成的
添加一条评论
I did the same dumb thing by running my Chinese-made Farberware brand FCP240 percolator without water. In no time, I found that I had damaged it and now it won’t heat. I suspect the element has burned out because no water was in the pot. How do I replace the element? These things should not be disposable, they ought to be repairable.
这个答案有帮助吗?
得分 0
添加一条评论
There maybe a thermal switch that lets go. So that there is no fire. Now try to find a replacement maybe a job.
这个答案有帮助吗?
得分 0
添加一条评论
I just plugged in my 6 months old Farberware percolator with no water and smelled it burning within 2 minutes. I’ve let it cool and it still WON’T work. Happy Thanksgiving without my morning coffee! LOL! I’m calling Farberware and asking for a replacement.
这个答案有帮助吗?
得分 0
1条评论:
I too turned percolator on no water… it discolored the metal inside to a rainbow of colors, but it still works. HOWEVER I noticed that it looks like it has small grains of natural sugar which it’s not ! where the spout attaches to the percolator body. WHAT is this??
How is the spout attached to pot at factory -, is it some sort of adhesive that is grainy that the hot pot unleashed Thank U so much for ur help.
完成的
添加一条评论
添加你的答案
David Weber 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 73
总计 17,775
