跳转到主内容
苹果订单编号为MC007LL/A / 27" 2560x1440 分辨率的显示器。
79 个问题 查看全部
Display won't turn on. Power works
Hello!
I have this apple display which doesn't work. The magsafe works, the USB works, the speakers works, and the computer recognises the screen, in the screen settings. However there is no display in the screen. I've disassembled the display, and no fuses seems broken on either power supply or the logic board. Could someone gie me a hint towards which of the two to replace? Could this maybe be a cable?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Take a flashlight and with the system & display all hooked up and running see if you can see the faint image of your desktop by placing the flashlight on the glass at a sharp angle. If you do your backlight logic needs repair. The LED driver logic chip has a tendency to burnout on these displays.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Christian Holm 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 2,350
