跳转到主内容
Standard and high definition handheld video cameras by Sony.
116 个问题 查看全部
sony handycam TRV608 code 31:22 Film does not roll
Everything else works okay electrical. But the film will not roll to record. I have tried taking the battery out for 2 minutes shoving it back in. Hitting the reset button nothing helps. Smacking it a few times does not help. some say there is a black roller in there. There is not on this model to fiddle with. Got any solvent ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Paul Gibson, looks like a slap on the back is your resolution :-) anyhow read the forum on here and see if that helps you out. http://www.pechorin.com/m/2004/10/23/Err...
then there is a little bit more of a technical error resolution on camerahacker.com and here are the images that you need to check out on your cam and see if it looks like something that might be wrong with your cam. Hope this will help you out.
Here is the good news. I just found the SERVICE MANUAL for your camera and have it for you to share on my file server. You will have to download all 3 parts. This should help you fix your camera.
Part 1
Part 2
Part 3
这个答案有帮助吗?
得分 2
1条评论:
+ nice research
完成的
添加一条评论
tHAT PART IS SO DAINTY i WOUNDER IF IT IS MISSING. bUT IS WHAT i THINK IS THAT THE MOTOR IS SHOT BECAUSE IT DOES NOT SEEM TO TURN
这个答案有帮助吗?
得分 0
1条评论:
YOu do have access to the field manual, take it apart and check it out. It tells you what to look for as well as the witirng and traceson the board to make it easier to troubleshoot. I am certain you will get there :)
完成的
添加一条评论
添加你的答案
Paul Gibson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 3,546
