跳转到主内容
型号A1040 / 10, 15, 20, 30, 或 40 GB 硬盘/ 中央转盘上方有四个触控激活 LED 背光按键
97 个问题 查看全部
Replaced battery but iPod still doesn't charge
I recently replaced the battery in my 3rd Generation iPod (A1040 20GB). It briefly powered up, worked and played music but the battery was low on charge and it quickly died. However, when I connected it to a wall charger it wouldn't charge. I have the same result when I connect it USB to a computer. I've tried several different kinds of wall chargers with the same results. When I plug it in it will briefly flash the Apple logo then go to a battery icon with a triangle with an exclamation point in it. I appreciate any help.
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
5个答案
最有帮助的答案
Are you trying to charge it via USB? You need to use a 30-pin to firewire cable and charger, or an iPod dock. The 3rd gen iPod can’t charge with a USB cable like the other iPods can.
这个答案有帮助吗?
得分 1
添加一条评论
Have you tried replacing the charging port?
这个答案有帮助吗?
得分 0
1条评论:
I have not. I'll explore that option, thanks for your response.
完成的
添加一条评论
You can either try a MB with the charge port already on it or a new charge port by soldering. But that's the next step. It's been hard finding main boards for these these days though
这个答案有帮助吗?
得分 0
2条评论:
By "MB" are you referring to the logic board? (IF192-001-1).
完成的
Yes that's what I meant . MB short had for main board
完成的
添加一条评论
I have this same issue.
I found two burnt out chips next to eachother on the motherboard.
这个答案有帮助吗?
得分 0
添加一条评论
I’m having the same problem with my 15GB model, I’m thinking of replacing the dock connector and cleaning up the motherboard to avoid any possible shorting. You could try this:
Connecting the iPod to the FW charger without the battery (open up the iPod and disconnect the battery), if it turns on then the battery might be faulty.
这个答案有帮助吗?
得分 0
1条评论:
what is the fw charger i have one of these took the battery out was wondering if it could be hard wired to bypass the battery.
完成的
添加一条评论
添加你的答案
Brian Martin 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 11
过去 30 天: 17
总计 410
