跳转到主内容
The second generation model's body has a wider track and longer wheelbase than the previous MDX. The engine was upgraded to a 3.7 liter V6 tuned for 300 hp. It accelerates from 0-60 mph in 6.5 seconds, one of the most powerful engines Honda has produced to date.
10 个问题 查看全部
Why is my idiot light on a 2007 Acura DMC saying "Battery not charging
I have a 2007 Acura DMX. Today (11/21/2017) I took the car out in a heavy rain. Eventually, I lost power. Pulled over side of the road, waited awhile and started car up again. Idiot light came on to say "Battery not charging" but I could run the car. However, power steering was totally gone and had great difficulty in turning the wheel in either direction. I thought everything had gotten soaked from the heavy rain. It is now 8 hours later. Car is parked in a warm garage in my house. Turned up car again. Again, idiot light came on, "Battery not charging". What should I do in this situation. Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@expofrosty double check your belts. Since you have no power steering and your "Battery not charging" could be a sign of a broken alternator belt. If the belt is okay you will have to consider to get your alternator checked (try places like Autozone or your dealer) with a worst case scenario of replacing your alternator. Check on here for that.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Bob FitzPatrick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 154
