跳转到主内容
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
754 个问题 查看全部
replaced screen and battery
replaced battery and screen, followed the manual and checked the connections, unit was charged and it does not work.
Update
The screen got damaged in the car. I figured that the unit is 5 yrs old so as long as I am opening the unit might as well replace the battery. I charged the battery but did not try connecting to Itunes.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
评论:
okay so what does it do? Anything, blank screen, does itunes recognize it? why did you replace those items?
完成的
添加一条评论
2个回答
已选择的解决方案
bkan209, I would open it up again and triple check the connections. the display connector has a tendency in going in somewhat crooked and can be difficult to manipulate. The battery connector is just as tricky at times. Make sure the tab is up and that you insert the cable deep enough, then replace the locking tab by pushing it down. I would definitely try to connect it to itunes or at least you computer so as to see if the computer recognizes it. You may not see it because of your display. Give it a try and let us know.
这个答案有帮助吗?
得分 5
添加一条评论
Before you open it up, did you try turning it on while charging? That could narrow the problem down to being just the battery that isn't connected proberly.
I'v made a sketch of the locking mechanism:
http://shadowofcertainty.blogspot.com/20...
good luck.
这个答案有帮助吗?
得分 1
评论:
Pretty good representation. I also do not like the idea of using the opening tool to lift the clip, broke the connector of twice that way :-)
完成的
thanks, I used a wooden stick that I had fitted with a knife. But maybe it should read "careful" somewhere.
完成的
I now use a paperclip bend into an L-shape and place it under the clip pulling up and that minimizes the sideways prying force. None broken since :-)
完成的
good tip, tx
完成的
添加一条评论
添加你的答案
bkan209 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 645
