跳转到主内容
问题已关闭
Fans run at 6000 rpm, CPU is cooled, but never slowdowns fan.
Hi everybody,
my A1150 is running fine except for the fans, they're always rotating with topspeed.
I tried resetting the SMC and PRAM, tried fancontrol and the like, but the results stay the same:
As soon as I turn on the machine the fans are spinning at topspeed and never slow down thus keeeping an intense noise level :-(
CPU temperature is 25 to 35 degrees C° at max, so far so good, always a 'cool' MBP.
My thoughts are: fans are ok, cooling is ok, sensors are ok, otherwise the machine wouldn't be so cold.
But what is wrong then ?
Thanks for a hint
CeeGee@gmx.de
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
it actually could be broken temp sensor... it gives wrong readings, so system just speeds up the fan. also, are you sure, the fan is working properly? i know, it spins, but it could have the sensor for RPM wrong. check the speed of fans against the FanControl...
also, you might want to consider reinstalling your system. i once have done very quick reinstall, using hard drive from different macbook. worked for me, don't see the reason, why it wouldn't work for you...
also, check the grills, it might me clogged...
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,953
