跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Battery operated RC truck designed for rock crawling and off-road terrain. Made by Maisto Tech.
16 个问题 查看全部
Can the truck be tested or powered on without a remote?
We bought a used truck at a thrift store, and it didn't include a remote. Before we invest in a replacement of the remote, we'd like to test the actual truck to make sure it works. Is there any way to test the vehicle without a remote, such as turn on the motor?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
1个回答
已选择的解决方案
Hi!
Yeah, you could theoretically wire up some batteries to the motor if you can access the main circuit board and see in it does anything. While I don't own this this thing personally and never tried this, I don't see what could go wrong. Just be sure to wire the batteries/ power source up properly and avoid applying too much power.
PS: This will also be helpful.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
EJ M 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 77
