跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
299 个问题 查看全部
How can I replace the flash storage on the logic board?
After taking my iPad to a technician i was informed that the flash storage (located on the logic board) has failed. How can i fix this? Can the flash storage chip be replaced? Do i need to replace the whole logic board and if so how?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Technically speaking, the Flash storage can be replaced and it can also be upgraded. That said, this is not a trivial undertaking and there are a few caveats to consider. A repair shop that specializes in micro-soldering repairs and has access to a NAND programmer can do this. Depending on the original error (was it Error 4013?), the NAND may just need to be repaired by the programmer. Regardless, all of these options require removing the NAND IC, programming it (or repairing it) and then re-soldering it on the board.
这个答案有帮助吗?
得分 3
7条评论:
@refectio - Clearly not a DIY try of repair ;-}
完成的
@danj
Nope!
完成的
What information from the diagnosis would you guys ask from the technician that checked it out, to see what actually is the case?
完成的
Hi Genik. In order to properly diagnose your issue, I would ask you what the original problem was (why you brought to a shop) and what was the history of the device prior to this. For example, was the iPad dropped, damaged, previously repaired (cracked screen?) or if it came into contact with water.
The diagnostic you received is NAND related, which is not a common occurence. So the more we know about what the original problem and symptoms, the more we can guide you.
完成的
Hi Minho, well the iPad was never dropped, never damaged, never repaired and nor did it ever come even close to water.
Before this issue that devastated it, i did experience some shutdowns that i posted here (All of a sudden it shuts down) and a reboot disability posted here (My iPad wont boot, nor can I Restore it). Other than these issues nothing else, but i do believe that all those issues could of been a road map to guide me to this final stage that im into now.
Many thanks for the interest all your guys show, you've been very helpful ;-)
完成的
显示更多的2条评论
添加一条评论
The flash chip is not really replaceable by its self. You'll need to replace the full logic board. review this IFIXIT guide: iPad Air Wi-Fi Logic Board Replacement
Update (11/16/2017)
Review the IFIXIT teardown here: iPad Air LTE Teardown. The logic board is basically the same as your WiFi only model. Jump down to Step17 to see all the guts and gore of the logic board ;-}
As for getting the part IFIXIT gets them from time to time but quickly are sold out so you could put in your request to be notified here: iPad Air Wi-Fi Logic Board. Just make sure you select the correct one (memory size-wise). Here's one available now: iPad Air Logic Board, 64GB, WiFi, A1474. They also have other sizes.
iPad Air Wi-Fi Logic Board图片
产品
$99.99
iPad Air LTE图片
指南
难度:
中等
iPad Air Wi-Fi 主板图片
指南
iPad WiFi版 主板更换
难度:
非常困难
1 - 2 hours
这个答案有帮助吗?
得分 2
1条评论:
Is it possible to pinpoint the flash chip on a logic board photo, so i can know what exactly we are talking about? Where it is etc?
Also
- if Apple doesn't sell Logic Boards, who does, how can i get a replacement?
- suppose i do get a new Logic Board, is there some reprogramming needed to the new part, or any other kind of software attendance so that the iPad is ready?
完成的
添加一条评论
添加你的答案
genik 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 35
总计 3,607
