跳转到主内容
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
426 个问题 查看全部
How do I fix my broken xbox one S sync button?
Okay so i figured out around two days ago i tried syncing my controller to me xbox one S but it wouldnt work i pressed the sync button on my xbox and i couldnt hear a click sound it makes normally when you sync a controller is a peice missing or is my sync button broken?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
添加一条评论
14个答案
最有帮助的答案
Plug Controller in USB.
2. Hold Power Button for 10 seconds.
3. Unplug the Power Cord for 10 seconds.
4. Plug Power Cord back in to Xbox.
5. Power On Xbox Press Power Button on Console.
6. Soft Power down Xbox Press Button once.
7. Disconnect USB from Xbox and Controller.
8. Power on Xbox with Controller.
You're Welcome. Enjoy!
I found this on a different page and it worked!!!!
这个答案有帮助吗?
得分 13
20条评论:
Didn’t work At all
完成的
It worked for me
完成的
It works! Thank you sooooo much
完成的
dude instructions are so unclear that its not even funny
完成的
This didn’t work at all dude actually post something helpful
完成的
显示更多的15条评论
添加一条评论
With mine all I had to do was take the disk out and boom problem solved so make sure there's no disk in when ur trying to sync.
这个答案有帮助吗?
得分 2
2条评论:
Same I was really suprised
完成的
thank you sm for this you fixed my issue
完成的
添加一条评论
How to fix the problem and it’s broke
这个答案有帮助吗?
得分 1
1条评论:
Use a pencil, when it broke off when I touched it with my finger, I used a pencil and it worked
完成的
添加一条评论
You can get a new one but you can also sync your controllers by using the USB port in the back of the Xbox One mine is broken as well so I just use the USB port to sync my controllers to the Xbox
这个答案有帮助吗?
得分 0
2条评论:
okay thanks for letting me know but how do i sync my controllers to my USB by the way im jack nutter who asked the question i just had to switch my profile though
完成的
How do I do this?!
完成的
添加一条评论
I know this space is for an answer but I'm having major problems with the sync I press it and it clicks but it doesn't flash plz help
这个答案有帮助吗?
得分 0
3条评论:
Mine does that aswell and it’s annoying as because I can’t play Xbox now
完成的
Me too, someone help!!!
完成的
connect a usb cable to the controller and the usb port on your xbox. Try all of them, as on my Xbox One there is one that doesn't work
完成的
添加一条评论
Other answers worked finally. Annoying product
这个答案有帮助吗?
得分 0
添加一条评论
yes but is broken and this is not working
这个答案有帮助吗?
得分 0
添加一条评论
There's 2 Sync Buttons, one to the left of the power button, and one below the power button on the black base, the second one is the one you have to press in order to pair any device you have.
这个答案有帮助吗?
得分 0
1条评论:
Where is this second sync button and how do I use it?
完成的
添加一条评论
I took mine apart and found the actual bind button itself had fallen away from the board. I haven’t mustered up the courage yet to attempt to solder it back on, but I have a feeling that is the only way to fix it.
这个答案有帮助吗?
得分 0
添加一条评论
There should be a USB plug in on the back of the Xbox. So grab the charger you use for the controller and plug it into the back and plug it into your controller. It worked for my brother.
这个答案有帮助吗?
得分 0
添加一条评论
Hard reset the Xbox, no data will be lost other than cache, it might work after.
这个答案有帮助吗?
得分 0
添加一条评论
When my sync button quit working I replaced the rf module. Only cost me like 30 dollars for that and the tools
这个答案有帮助吗?
得分 0
添加一条评论
idk if this will work for you guys but I moved everything in front of my xbox and made sure nothing blocked the pairing sensor and put my controller super close to the sensor and it worked
这个答案有帮助吗?
得分 0
添加一条评论
Address:
Peer Shaheb Lane, Dhaka 1217
Phone:
01798-777803
Website:
https://nashidbashar.com/seo-expert-in-b...
GMB:
https://g.page/nashidbashar
Nashid Bashar is a Clickminded certified SEO expert in Bangladesh. He is serving as an SEO consultant in California-based Company ProAir Industries, Inc.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jack Nutter 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 26
过去 30 天: 111
总计 48,449
