跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
问题已关闭
My 3GS dies at any battery percentage, is it a battery problem?
Hi,
My 1.5 year 3GS, it dies even when the battery is 70% or 80%. Then, I couldn't turn it on unless I use the charger since it says no battery. But when it restarts, the battery indicates 70% though.
Should I replace the battery? Any suggestions?
Thanks a lot!
Paul
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Thanks guys for your help.
I just found out that the problem is not the battery. It is from my carrier Rogers.
The story is that I ordered a new battery from iFixit, installed it and the problem is the same.
Desperately, I decided not to use that iphone, and took out the SIM card. You know what? The problem gets fixed. BTW, I am using a pre-paid card.
完成的
Really? thats cool. do mind commenting again if it is still working? Maybe the sim card was shorting out the phone or something like that?
完成的
添加一条评论
4个答案
已选择的解决方案
Paul, i would start with the battery. It sounds like it, even when it is odd that it still shows 70% charge. Sometimes it is easier to treat the patient (phone) than the monitor (battery gauge) it is also the easier and most economical fix. Just my 2 cents, good luck.
这个答案有帮助吗?
得分 1
2条评论:
Thanks, it just died @97% after I did a full charging (I charged extra 2 hours after it said 100%). I think it is the battery problem.
btw, I did a very fresh restore today, so it shouldn't be the issue due to jailbreak or apps.
完成的
I agree and do find that the battery replacement is at least a good start. It usually narrows it down without costing an arm and a leg. Good Luck
完成的
添加一条评论
I had the same problem I after visiting the apple store I was told the problem was a bad battery.
Replace the battery and the iphone will be fine.
这个答案有帮助吗?
得分 0
添加一条评论
Paul,
Did you ever get 3GS working again? You say you didn't use that phone, so can I assume you got a new phone? I just don't quite understand your answer and if you actually found the problem. I've seen a bunch of these threads and so far no one coming forth to say battery replacement works or doesn't work. If you definitively found the issue I'd really appreciate as much detail as you can provide.
这个答案有帮助吗?
得分 0
2条评论:
his answer says it was the SIM from his network... not the battery.
完成的
I tried replacing the SIM today, however the problem persists. I have a replacement battery on the way and will report back if that resolves the issue.
完成的
添加一条评论
I swapped the battery and that resolved the issue for me. Phone is acting like it's old self again. No random shutdowns at 80% charged. I recommend the battery swap to anyone experiencing this problem. But please watch the how to video and be very careful of connector #3, it's very fragile.
Good luck all, Mike
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 7,449
