跳转到主内容
Repair guides and support for Saturn's 2nd generation SC, SL, and SW.
19 个问题 查看全部
Manuel transmission 1999 Saturn sl, replace
5 speed Manuel trans replacement
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
William Emerson excellent write up about the how-to on here. Definitely not an easy job. I would also recommend that if you need more information on this extensive task, visit your local library and see if they have the manual.
这个答案有帮助吗?
得分 2
评论:
Thank you for your help, I have a 1999 3 door Saturn 5speed Manuel trans, mine is broken looking for another one
完成的
William Emerson not sure where you are located. I would connect with a local recycler. I guess that's what they call the wrecking yards now. Even if they do not have it they can probably find one for you.
完成的
添加一条评论
添加你的答案
William Emerson 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 51
