跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Phone won't turn on at all!
Hi guys, I'm having some big issues with my old iPhone 5. First off I did a lock button and home button reset and it brought it to a new start up menu where I had to connect to wifi and restart the phone as I 'restarted it' which was unusual. But the device couldn't find my sim so it wouldn't start. So I taken matters into my own hands and as the phone got soap in it once I thought the insides could be hot. So i got a hair dryer and tried to dry the damp looking phone for 3 minutes. I then went to turn the phone on and it now won't turn on at all! Any help for what I could of broken?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
It is almost impossible to know the issue based on the information, as so many parts could have been compromised. I would start with getting an amp meter, so you can see if the phone is drawing any power, to try and focus in on what is causing the problem. If the phone is drawing a normal amount of power (around 1 amp), then it would point towards some kind of display issue (bad screen, bad backlight, damaged fpc connector etc), but if it's not drawing any power or minimal power, it would likely be an issue with the board.
这个答案有帮助吗?
得分 1
添加一条评论
Hi David, thanks for your input I have a multi meter at work so I’ll give it a try! Where would you place the amp meters rods on the phone to see where the power is coming from? The screen was definitely damaged I need to place a new one on it as well so I’m hoping that’s the case! If the board is broken then I take it that the phone is dead? Is there any way to retrieve the data of it? I appreciate all of this help thank you!
这个答案有帮助吗?
得分 0
1条评论:
so you said you got soap in it and only dried it with a hair dryer. you will need to check the board for damage also just drying it wont help. it will need cleaned in an ultrasonic cleaner. any number of things on the board could be the cause of it not turning on. so take the board out and have a look over it. even take photos and post them as it could just be a cap has blown
完成的
添加一条评论
Hi guys, just to let you know the phone works now! I placed a new screen on it and left it on charge and it just turned on, the flex cable was damaged cheers for all of your input. To get the sim to work I heated up the sim tray which has soap and then blew the phone out with an air gun... Rightly or wrongly doing so its fixed!!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rhys 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 10
总计 57
