跳转到主内容
雅达利视频电脑系统(VCS)有MOS科技的 6507 CPU ,频率为1.19MHz
32 个问题 查看全部
What kind of cable is This?
This cable is for my Atari, but I need another one for my Sega Master System, i wanted to know what the cable is called. People call it a RF Input, but for some reason the cable is not called a rf cable so I don't know how to search up this exact cable
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@krisow those are RCA cables
Update (11/11/2017)
You can still use the RCA cable. Check on here or on here for a replacement
这个答案有帮助吗?
得分 2
1条评论:
I've searched that cable up on Ebay and its not the right cable sadly, they're very alike, but not the same
完成的
添加一条评论
It is called an RF video cable. You can find them on Amazon just look up the term RF video game cord or cable .
And RCA cable would be a temporary fix. However you would get a little bit of a loss of signal because of the make up of the center core of the wire, it is a little thicker and has an 8 ohm impedance. The RCA contact on the outside is a little thinner as well versus the thicker contacts on the standard RF cable.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Krisow 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 20
总计 857
