stripped out triPod mounting hole in the aw130
how can you fix a stripped tripod mounting hole in the aw130
Camera tripod mounts are a standardized 1/4-20 threaded rod. That is, 1/4 in diameter by 20 threads per inch. Cameras usually feature either pieces of metal that have a threaded 1/4-20 hole or a stamped 1/4-20 insert. When manufacturers penny pinch to oblivion, they tap or injection mold a 1/4-20 hole into plastic. In this case, Nikon decided to cheap out and implement a plastic 1/4-20 mount on your camera. Unfortunately, there isn't much you can do to re-thread that mount hole on your camera.
Usually, when a threaded hole strips in a piece of metal, you have a few options. You can clean up the threads by running a tap for the specific type of machined hole through the threads to remove any unwanted debris or buildups. Or you can drill deeper and thread that portion and use a longer bolt. Or worst case scenario, you can drill the hole out and heli-coil the hole.
In your case, you can't do any of these options, because you have a plastic 1/4-20 mount. Your best option is to try to buy a replacement part. Unfortunately, Nikon decided to stop selling consumers replacement parts, and force all consumers to pay for in-house repair. Source:
https://petapixel.com/2013/01/13/nikon-n...
I just checked nikon's new part page and all they sell are rubber grips and some double sided tape. I checked your model and there are no parts available.
In addition, here's someone who has the exact same issue:
https://www.facebook.com/nikonsingapore/...
Your Options:
Good luck!
这个答案有帮助吗?
Do a search on Amazon or Ebay for “Tripod Mount Ring Collar.” This is a collar with a tripod screw mount in the base. Tripod screws into the base and the collar fits around your camera’s lens. Take care to measure your camera lens and look for a ring collar that will work with that size. Prices range from about $20 on up.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 734
