跳转到主内容
Wi-Fi版的iPad Mini 2指南。2013年10月22号发布同年11月12号上市。iPad Mini 2就是配备了Retina显示屏的iPad Mini,在更小尺寸的的7.9寸屏幕上拥有和iPad Air相同的像素。
220 个问题 查看全部
iPad mini 2 won't charge
My iPad fell off the bed while charging, bending the Lightning connector slightly, so that I had to prop the cable up on something before it would charge.
Now, though, it has gotten worse, to the point of hardly charging at all.
Is there anything I can do to remedy this, short of replacing the logic board or doing microsoldering?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
[] try another cable if they work...
[] if the pins have been damaged but workable, try something like a "magnetic usb charger" for Iphone/ipad, they're cheap and they snug fit into the device's port and wont have to be removed at all.
It helps if a little movement/or angular variation in your charging cable causes the charging issue.
这个答案有帮助吗?
得分 0
2条评论:
Oh wow. I had no idea that existed. I'll give it a try. Different cables don't help, but perhaps this will. At this point I have to wiggle it to get it to register a connection at all, and it won't connect consistently. I'm pretty sure I bent the connector somehow, but I'm not quite sure what is damaged.
完成的
yeah give it a try and see if helps, otherwise you'd probably have to replace your connector . thanks
完成的
添加一条评论
添加你的答案
Calion 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 159
