跳转到主内容
7.9 inch display / Model A1454 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
28 个问题 查看全部
Which is the best Double tape for Remplaced Screen?
Which is the best double tape to stick the ipad? Or the most advisable glue to stick it?
When mounting the ipad mini I notice that I do not hit correctly.
And what would be the best way to remove the excess tape that comes with the original screen?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Thank you, I appreciate your help
完成的
添加一条评论
2个答案
已选择的解决方案
Acetone works well to remove the old adhesive, then clean with IPA. As for the adhesives, the Tesa Tape sold here at iFixit is probably the strongest tape you will find but it is only sold in rolls. If you want pre-cut tape for the iPad, consider BowlerTech or TapeTemplates.
Tesa 61395 Tape图片
产品
Tesa 61395 Tape
$5.99
这个答案有帮助吗?
得分 3
1条评论:
完成的
添加一条评论
Personally, I use https://www.amazon.com/gp/product/B00OZG...
Sometimes the factory adhesive is a bit thick and doesn't set very well even with heating, it can also make the home button sit higher so it doesnt make contact.
If you apply about 80C heat to the existing tape it should soften it enough to help peel it back off.
这个答案有帮助吗?
得分 2
1条评论:
完成的
添加一条评论
添加你的答案
Christian 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 48
总计 4,492
