跳转到主内容
加入维修社区 - 创建账户
三星新旗舰的大号版本,盖乐世S8+。发布于2017年4月。
Device doesn't charge after display replacement.
Hey, I needed to replace the display of an S8 Plus. Unfortunately it doesn't charge after the replacement. The temperature is too low. I tried a new battery and the phone starts but still it won't charge and I get the same error that device temperature is too low. Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
Hi. I had the same problem for 2 s8 and s8+. Try to assemble the whole phones, including screws, without back cover and put it in charge. It worked for me, i hope it will do it for you as well.
这个答案有帮助吗?
得分 2
2条评论:
Thank you! It worked for me too!
完成的
Thanks was helping to save my day. you really have to assemble before charging . superb
完成的
添加一条评论
最有帮助的答案
Charging port is most likely faulty. I take it you used a replacement display assembly which included LCD with frame and charging port with it?
I'm not 100% sure about this but the charging port model label mismatch from the phone model can cause issues e.g SM-G920I with SM-G920F for example.
这个答案有帮助吗?
得分 2
1条评论:
No I had to take the original charging port, but I will try another one and tell you if it worked! Thank you :)
完成的
添加一条评论
If you have a Samsung Galaxy S8 or S8+, there’s no foolproof way to prevent it from damage.  Just get it serviced from the professional. That’s it !
Because doing all things on your own cannot get it run in the proper way.
Regards,
Gadget Genie
这个答案有帮助吗?
得分 1
添加一条评论
Check to see if you have the NFC installed
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
elreparero 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 3,321
