跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
How do I know when the logic board needs to be replaced?
I tried replacing my 5s screen with a sceeen i bought online but it seems it didn't work and now I'm wondering if it was a bad idea, i can't see anything on the screen when i try to turn it on, its veey confusing
I really need some help before my iPhone 5s is completely obsolete
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Did you power off the phone and disconnect the battery before removing the old screen and before putting the new one on? You can troubleshoot it by 1. seeing if itunes still sees it. 2. If it does, use a flashlight and point it at the screen when on to see if you see a faint image (If so, it;s a blown back light circuit 3. you can put your old screen back on to see if it works to know if you got a bad screen. and last, did you put the screws back in the same holes you got them out of around the LCD Shield? You can cause damage to the logic board with the wrong screws (Long screw damage). Write back and let us know what you find :) Good Luck!
这个答案有帮助吗?
得分 2
添加一条评论
screen not working after a replacement? there are plenty of causes for it.
Before starting, look for the following;
- All connectors are in tact. (no tears, disconnects, and clean)
- The battery is re-installed. (commonly the battery gets left unplugged on home repairs)
- The computer reads the device. (plug it in, itunes should recognize it as a locked device)
- There is no physical damage to the board. (scratches, missing/chipped components, etc)
1) Start with a redo. Open the device, Disassemble it as needed, and reconnect everything. something may be causing issues.
2) try a hard reset. (plug it in, and hold the power button, and the home button for a minimum of 15 seconds) see if you see the apple logo.
3) if this doesnt work, you could have a backlight issue. Shine a flashlight onto the screen and see if you can get a dim picture. if you see the outlines of your background, then you may have a backlight issue. in this case, start by trying to resolder the three connections on the top of the back of the screen, that leed to your backlight.
4) should these not be the case, you could have a bad screen. it happens often. at my store, we always try three before moving forward with other possibilities.
5) this point forward, you are likely looking at a board level issue. boards are usually not worth replacing, but if you can reflow some components, you may be able to get it working again. set your hot air rework nozzle to approximately 300-325, and airflow to medium. heat up the board localized around the screen connectors and see if the connectors are working.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Curtis O'brien 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 164
