跳转到主内容
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
114 个问题 查看全部
New harddrive will not show up during install of panther OS X
iBook G3 800Mhz 640ram
Using the instructions on website and the suggested 120gb WD hard drive from ifixit, I can not get the hard drive to be shown on the install OSX 10.3 software. The old hard drive works fine just a little small to really do anything with. This is my first apple computer. Is there some sort of bios setting or setup for an apple to recognize a new hard drive?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Thanks Mayer,
Your the best.
完成的
Glad to be of service. Thanks for a well stated question.
完成的
添加一条评论
1个答案
已选择的解决方案
It needs to be formatted before you can install a system. Start up from your system installation disk. Hold down "C" key. Go to the second screen pull down menu to Utilities -> Disk Utility and select the drive on the left and format it OSX Extended, give it one or more partition. Now you can install a system.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
nwasness 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,529
