跳转到主内容
修复你的物品
维修的权力
配件 & 工具
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
290 个问题 查看全部
Changed screen and now have only white screen when turn on computer
I changed the display screen with new one, turned on and get a white screen? checked all connections, even plugged in broken screen and it still lit up on part of glass not cracked. any ideas?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 1
评论:
What happened with the previous screen to need a replacement ?
完成的
Daughter dropped off desk and cracked the screen, ultimately had to send to Apple and was fixed
完成的
添加一条评论
LCD iPhone 屏幕维修套装
预算选项,涵盖在我们的终身保修中。
购买套装
LCD iPhone 屏幕维修套装
削减维修成本,而不是质量。
购买套装
3个回答
已选择的解决方案
The original screen had a small crack after falling off a desk and the bottom half of the screen was not working. Ordered a replacement screen and the replacement screen was faulty.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
surely this is a software problem. Try starting up from an external USB device with a known good system on it. If it boots, run Disk Utilities from the external drive and see if that will do the trick.
这个答案有帮助吗?
得分 2
添加一条评论
Maybe you have not connected all the wires. If it is not of this then you will need programming pairing which only Apple does, and because you replaced the screen yourself they may not do it because it is Apple .
这个答案有帮助吗?
得分 -1
评论:
Never heard of that before. There is no programming a screen.
完成的
I like to see some validation of this programming pairing. Could you give us a link?
完成的
添加一条评论
添加你的答案
herrky 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 151
