跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
114 个问题 查看全部
Is there any way to fix what I did?
I accidentally spilled toothpaste on my dsi xl about 6 months ago but i started needing it more so i thought i would ask if there is a way to fix it without paying for anything like a new hard drive or something like that. Anyone know the answer
Also the screws got rusted or stripped somehow it only happened to the three by the slot 1 card reader. How do i remove the screws???
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Where exactly did you spill toothpaste on the DSi?
完成的
I spilled it where the sd card slot is sorry i meant to put that
完成的
It's really hard to put toothpaste back in the tube.
完成的
添加一条评论
任天堂 Switch 套装
A quick fix to get back in the game
Shop Switch Kits
任天堂 Switch 套装
Shop Switch Kits
1个回答
最有帮助的答案
@magicalturtle use these guides to disassemble your DSi XL . Then clean everything with some sterile water and a soft brush (toothbrush will work) and follow that up with 90%+ isopropyl alcohol. This will dissipate the water and leftover residue. Let it air dry then reassemble.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Stan Smith 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 79
