跳转到主内容
为iPhone 6s 设计的充电后壳,由Apple在2015年12月发布。Smart Battery Case包括一个一体的电池来增长iPhone 6s的电池续航。
I dropped it in water and now not working
i dropped in water along with phone, phone is working fine but smart battery is not charging and if I plug iPhone 7 in it , smart battery is heating and phone discharging. i tried to charge the battery separately there is no sign of charging.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
The iPhone has IP67 water resistance, not the case. There is most likely a short.
这个答案有帮助吗?
得分 0
添加一条评论
Should I use the heat or cool option on the air dryer to air dry the charging case I need a an anser as soon as possible
这个答案有帮助吗?
得分 0
1条评论:
Heat but don’t use too much heat or you may cause a swollen battery.
完成的
添加一条评论
添加你的答案
ALSABT Dubai 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 2,637
