跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2686 个问题 查看全部
Won't let me end calls
Hi my IPhone 6s has a problem where if I make a call the screen goes black, if I press the home button the screen come back on shortly but it won't let me end the call with the red end call on screen. I have to reset by holding down the power button and home. Everything else seems to work ok.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
4个答案
已选择的解决方案
Sounds like you have a proximity sensor problem! How long have you had this phone? Did you buy it new or used? Has the screen been changed on it?
I believe the sensor to detect if it is up to your ear is out of position and always detecting something in front of it. Solutions could be to align the sensor correctly, or if the assembly is bad, to replace it.
Good luck!
这个答案有帮助吗?
得分 1
6条评论:
Hi it was the third party screen that's the problem, any idea why it would do this ? Any fix?
完成的
That can be common - Did the replacement screen come with the front camera and speaker installed? It is not un common for the sensor to be aligned poorly, or there is a possibility that the sensor assembly is defective.
Some things you can try- if you are curious enough
Remove the front camera lightsenor/prox flex cable, and test it off of the screen with your finger - to see if it activates. You might need 3 hands to do this though! and do be careful not to put any stress on the ribbons/connectors or you could cause some pretty serious damage.
If it works - then it was most likely an alignment issue and the sensor is blocked by the screen
If it doesn't work, then it is a faulty front camera flex
Here is a walk through on how to take the flex assembly out.
iPhone 6s 前置摄像头与光线传感器组件更换
And here is a new one if yours is bad!
iPhone 6s Front Camera and Sensor Cable
Good luck :)
完成的
I have this problem and I have found if I connect head phones then it allows me to stop the call and the black screen goes away ... why would this be ? Spoke to apple and they just tell me its a hardware problem and take it to the store or it could be software ... they obviously don't know. I also have iphone 6S and it started after one of their updates a while back last year and I just live with it but its getting worse. Any suggestions as to what it could be ?
完成的
@lynnmc it is most likely the front camera assembly. Part of that assembly is a proximity sensor that detects when you phone is up to your face. It blacka out and blocks the screen so you don't press buttons. Using headphones over-rides that function as it seems you have an external headset attached.
I would open the phone and see if that sensor is aligned. Check out the ifixit guides I linked above. An easy way to test it is with voice recorder. During recording the screen will blackout if it is close to something or missaligned.
Best of luck!
完成的
I too have an iPhone 6 and the only thing that works is putting in the headphones....this started happening from a back update also.
完成的
显示更多的1条评论
添加一条评论
Hi the problem was the screen, any know why the screen would do this?
这个答案有帮助吗?
得分 1
1条评论:
Check screen protector
完成的
添加一条评论
I had this problem, and it was because of a slightly misaligned screen protector
这个答案有帮助吗?
得分 1
1条评论:
Same problem my mother had with her Iphone XR screen protector was lifted slightly near sensor so I removed it
完成的
添加一条评论
Probably water touched the screen. Having same problem. I left the phone in the bathroom and some water splashed on the screen.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Daneil 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 14
总计 30,595
