跳转到主内容
Repair guides and support for Android phones manufactured by HMD, including feature phones and smartphones with Nokia and HMD brands.
195 个问题 查看全部
How can I install app from playstore in Nokia x2 and will it work?
MY Nokia X2 currently have Nokia X software platform 2.0 . I want to install different software from play store but could not successed as Nokia X2 doesnot support google's playstore. Is there a way to upgrade or make the OS( Anroid) of Nokia to latest anroid?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
See this article.
https://nokiapoweruser.com/six-top-andro...
这个答案有帮助吗?
得分 1
2条评论:
I have used amazon store and apk mirror, yes they are great alternative but then it doesnot give the flexibility of using anroid and google playstore.
完成的
Then see if this will help.
https://nokiapoweruser.com/nokia-x2-tool...
I warn you rooting and other modifications will compromise the security in the phone.
完成的
添加一条评论
Nokia X2 should run Android 4.3 at least so it should be able to use the Google Playstore.
this might help:
http://www.androidpolice.com/2013/08/05/...
and try going to:
https://www.apkmirror.com/
where you can download apps you'd normally find in the playstore, and even the playstore itself.
这个答案有帮助吗?
得分 0
添加一条评论
Google play store download
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sharad Neupane 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 2,290
