跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
624 个问题 查看全部
iPhone Doesn't Boot Up, Rescue Data
Hi,
I updated some apps and suddenly the iPhone SE crashed every night while charging. When I woke up I had to hard reset the device to make it work again. Then everything was ok.
After three nights it crashed again but a hard reset didn't do anything. The screen remains black.
Recovery mode is possible but iTunes can only reset, not update (grey button). And the display remains black, no Apple logo visible. Display broken?
Apple Support at the store can't help. They're pretty sure it's a hardware defect, not a software problem.
USB digital multimeter shows 0 to 0.33 A instead of 1.3. Maybe because the battery is already full? Or broken?
I don't have a backup of my data.
What can I do aside from giving my phone to a professional data recovery company? Do you have any idea why it doesn't boot up?
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
Instead of "professional data recovery company" I would look one that specializes in Apple devices. Most likely there is some simple logic board effects they will be able to fix and get your data, and perhaps even the phone.
try changing the battery
I don't think changing the battery will do much, iv seen an iPhone go into recovery mode from a bad battery but not dfu mode. If it's in dfu mode something major has gone wrong.
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
1个答案
The phone is in dfu mode and not recovery mode. This is why there's no update option. There arnt an awful lot of components that will knock an iPhone into dfu mode, as a board will still happily boot with a lot of the ics installed on the board. My bet is the nand requires reballing by the things you have told us. Other than that the cpu / ram has possibly had it.
I'd send it to iPad rehab, sts telecom etc, either of those should be able to sort it. I wouldn't send it to a data recovery company, you need a place that specialises in board repair like the two above suggestions.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Tscholo 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 36
