跳转到主内容
Furby was a popular electronic robotic toy resembling a hamster/owl-like creature which went through a period of being a "must-have" toy following its launch in the holiday season of 1998, with continual sales until 2000. Furbies sold 1.8 million units in 1998, 14 million units in 1999, and altogether in its three years of original production, Furbies sold over 40 million units.
85 个问题 查看全部
New out of box 1998 furby not talking or making sound.
Just took it out of the packaging first time ever. I put brand new batteries in it as well. It moves and wiggles but does not talk or make any noise.... what is wrong?!? do i need a new speaker?? This one has never been used....ever.... =(
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
6个答案
最有帮助的答案
@dragonfly10 here is my answer to a similar question "Once you have installed fresh batteries, and Furby still won't talk, push the reset button and the tongue at the same time when the Furby is turned on. To turn on the Furby, turn it completely upside down and back upright again. After that you can see if the speaker needs to be replacing by checking this site out. I would get to the "tummy switch" and check the circuit from there. You do have a couple of choices here. Check the switch, then the speaker. Check the connector for both. You will need a multimeter to check those. Follow the schematic to work on your Furby's voice, and check on here for directions on how to skin the Furby." Hope this helps, good luck.
这个答案有帮助吗?
得分 3
2条评论:
thank you!!!
完成的
It still doesn't work...I mean it is like 25 years old but....I don't know what to do..
完成的
添加一条评论
Sometimes when things sit for a long time it can cause them to get jammed over time. Maybe the wires connecting to the speaker came loose over time!
这个答案有帮助吗?
得分 0
添加一条评论
I think the only way is to skin your furby, and find a video on how to fix a speaker, or swap it out for a new one.
这个答案有帮助吗?
得分 0
添加一条评论
I fixed my furby who had stopped talking I stuck a gem clip in his speaker and he started back talking
这个答案有帮助吗?
得分 0
2条评论:
What’s a gem clip can you post pictures of clip & show where to exactly to put it thanks
完成的
I a gem Clip just one of those coated colored paper clips? thanks
完成的
添加一条评论
Go on eBay and buy a new one
这个答案有帮助吗?
得分 0
添加一条评论
O what is my Furby saying?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Becca 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 85
总计 9,370
