I changed mother board and PS4 won't turn on.
I replaced the mother board on my PS4, and it won't turn on. When I push the on/off button it beeps once, the blue light comes on for a second, and then it turns off/shuts off.
What do I check and please, information on fixing.
Thanks,
Keith
did you change the board on the disc drive aswell as they are both paired
由 daniel 完成的
yes the board for disc drive came with motherboard
由 Keith Pike 完成的
people say that theirs will beep once even while unplugged...mine won't beep once while unplugged...is it suppose to?...
由 Keith Pike 完成的
think it should only beep when turning on and off, just go back over everything and make sure the heat sink is screwed tightly
由 daniel 完成的
thanks Daniel...took back a part and rechecked everything...all ok...decided to replace motherboard battery on chance it was problem...it was...thanks again Daniel!!
由 Keith Pike 完成的
显示更多的1条评论
