跳转到主内容
Repair and disassembly guides for guitar amplifiers.
71 个问题 查看全部
My 15W AMP is making a buzzy noise, what will the issue be?
I have a 15W AMP but is making a buzzy sound even when is not connected to the guitar and sometimes you can not hear the guitar went plying, I replace my cable. I have no idea where to start, please help ????
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Unplug all the input from your amplifier,if the buzz or loud hum still there,you might have a problem with its power supply..look for deformed high valued (usually valued at 1000 uF or more)capacitors their top is flat not rounded.If you find one or two replace them,it should correct the problem,good luck !
P.S. Also toggle the top of the capacitors they should not turn loose or else their wire terminal is corroded .
这个答案有帮助吗?
得分 0
添加一条评论
Capacitors are okay no issues the problem start when I plugged the cable even when the guitar is not connected !!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Miguel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 131
