跳转到主内容
7.1 Megapixel compact point-and-shoot digital camera released in September 2006.
1 个问题 查看全部
问题已关闭
Canon wont turn on.
I opened the camera to clean it and it was working, then after i closed it back up it stopped working. I push the power button and nothing happens.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
danielle, did you take it apart to clean it or did you just open the most common compartments? Of course follow the advise that Gabe wrote if you took it apart, always double check your work first. I would also make sure that the battery is inserted the right way and that the battery makes contacts with the posts. sometimes the battery connection to get knocked off or bend and do not connect. Make sure that you are working with a good battery that has a charge. Hope you get it working again and if not let us know what you did to the camera to clean it out. Good Luck
这个答案有帮助吗?
得分 2
添加一条评论
Take it apart again and put it back together. Make sure all the ribbons are connected and you did not miss a thing, that is most likely what happened.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,579
