Dell Monitor is Blinking continiously?
I have Dell monitor (Dell 22 " SE2216H)). When I connect it to camera's installed in my home through HDMI Cable it blink continuously. But when I connect it ith my laptop HDMI, it works fine. I dont understand why cameras are blinking?
1条评论
Hi,
Has it worked before OK?
Try switching off the monitor and unplugging everything from it, including the power and leave it for 5 minutes. Then plug in the power and then the HDMI cable from your camera source , switch on and see if it works.
If it doesn't what make and model of "box" are the cameras connected to and then connected via HDMI to the monitor if this is your setup? Is the "box" HDCP compliant. If not and since your monitor is there may be a compatibility issue between the two
由 jayeff 完成的
