跳转到主内容
Released Spring 2015 RCA 7-in 8GB Adroid 4.2 Tablet
25 个问题 查看全部
My rca tablet keeps going to sleep.
Tablet goes to sleep every couple of seconds.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Judi Lopez tell us exactly what it does and when it does this. Also, please verify that your tablet is a RCA RCT6378W2
完成的
rct6513w87
same problem
完成的
I'm having the same issue too.
完成的
添加一条评论
2个答案
已选择的解决方案
Hi
Check in Settings > Device > Display > Sleep to see what time period is set.
这个答案有帮助吗?
得分 2
2条评论:
I've done that, and it still goes to sleep after five seconds.
完成的
doesnt work on mine either. sleeps every 10 seconds. sleep is set on never
完成的
添加一条评论
i had the same problem. Sleep timer was set at never. I even went into the HDMI setting and put that timer on never. still it timed out every 10 seconds. i had the same thing happen a couple months ago on a different but same tablet and I did so much that i forgot what i did the first time. go figure. Now I am here to say that more than likely its a timer set in an app you have downloaded. which one? Who knows. Start with your cleaner app. I did it the easy way.. I factory reset it and chose not to forward any apps over from my other device. Boom!!! Now it works perfectly. Now I will go download a cleaner and see what happens...then move on from there. Im glad its over cause that can make a person really irritated. Good luck.
这个答案有帮助吗?
得分 0
2条评论:
What if was like this the second you turned it on, right out of the box? I just have no idea what to do. Do you think that I should still do factory reset?
完成的
I'm having the same problem
完成的
添加一条评论
添加你的答案
Judi Lopez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,214
