跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Phone Won't update to iOS 11.0.3
I have not had issues with my phone in the past, nor did I after I updated to ios 11. However when I tried to update to 11.0.3, I keep gettting an error saying that the update cannot be installed. I have retried the update as well as deleting, redownloading, and then retrying both to no avail. How can I fix this?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
SAome time air update error causes error due to storage full or battery level low,if you have to update anymore use iTunes or 3u tool to update manually before restore backup important data and restore and update not only update.
完成的
添加一条评论
2个答案
最有帮助的答案
It sounds as if your phone storage is full. Try deleting some apps and photos to free up room. Other than that, is there any reason for failure? Try clicking install and leave it alone. Press the button and walk away.
Hope this helps!
这个答案有帮助吗?
得分 2
6条评论:
I checked and I have over a gigabyte of memory left open. I tried again and it propmtly failed in under a minute. I'm at a bit of a loss here...
完成的
@jack35 Still try freeing some space. It requires more than you know.
完成的
The problem I have right now is that 7 out of 16 gigabytes is "System" memory and another gygabyte "Settings". I have 7 gigabytes of stuff I put on the phone but it's spread out through a number of apps I'd rather not delate. What should I do?
完成的
@jack35, If you have any photos on it move them to your Mac/PC/cloud storage. If you have any videos downloaded delete them. If you notice any apps are taking up more space than they should, consider deleting them. Also, have you restarted it yet? It could be as simple as a force restart. 怎样强制重启 iPhone 6
完成的
Hard reset did the trick. I'm kinda facepalming for not trying the oldest trick in the book first...
完成的
显示更多的1条评论
添加一条评论
My iPhone 6S won't update past 11.0.3. when I go to check updates it says that it's up to date
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jack 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 10,301
