跳转到主内容
加入维修社区 - 创建账户
惠普于 2009 年 11 月 25 日发布的一体式台式机,搭载 AthlonII X2 250u 处理器。你可以在此找到维修手册和产品信息。
The computer won't boot
Hey guys,
I was at my parent's yesterday and they said their computer wasn't working anymore, so i took a look at it but i couldn't figure it out so i hope you guys can. When I try to start up the computer the power LED will only flash on and will go out in less than half a second. Furthermore after it has flashed the LED it will not do that again unless i remove the power cable and plug it back in. Does anyone have a possible solution?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Sounds like a short circuit. Could be anywhere. Have they gotten it wet lately? Any chance of corrosion? Humidity, ect...
由完成的 分享
添加一条评论
1个答案
已选择的解决方案
Sounds very much like a power supply problem. Does it have a separate power adapter, or does the mains lead plug directly into it? If you can somehow get your hands on a replacement power adapter that would be well worth trying. If not an exact replacement it will need to have the same size plug on the computer end, the same output voltage, and the same or greaterAmps (or Watts).
Otherwise, I'd take the back off and see if you can spot any domed electrolytic capacitors in the vicinity of where the power comes in. (See https://therestartproject.org/wiki/Basic...)
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
jasper flanderhijn 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 20
总计 652
