How to charge battery without logic board
HI
I have faulty Logic board ,most likely charging circuit on iPad 4
Is there a way to charge battery without using logic board so called " jump start" , as i am almost sure charging circuit is not function and battery not being charge , can i just use usb charger ,old usb cable ,strip down wires and connect red and ground directly to battery ?
Also
Should ipad works without battery connected to logic board? just lighting cable connected directly to logic board viaDock Connector Charging Port Flex Cable and usb to mac computer, should itunes detect it this way or needs battery ?many thanks
1条评论
Did you fix it? I have the same problem
由 xda.dev23 完成的
