跳转到主内容
非苹果电脑键盘维修指南。
242 个问题 查看全部
I spilled water on my keyboard, but it still (Kindof) works
Last night, I spilled water on my keyboard. It had drain holes so I figured it would be fine if I unplugged it and let it dry. I did just that, and when I came back today to play some video games, it seemed mostly dry, but my most important key, the W key, was giving me problems. Is there anything I can still do in an attempt to save my expensive keyboard?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
What the make and model number?
完成的
添加一条评论
1个答案
@tkmaida the only thing you can try and do is disassemble your keyboard. Then clean everything with 90%+ isopropyl alcohol and a soft brush. Clean it very good, every nook and cranny (meaning every connector every cable end) then let it sit to dry. After that reassemble and try again. Most likely your keyboard may have shorted out, but you never know until you tried to fix it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tristan M. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 304
