How to have SSD and HDD with a 2x2,5" bracket in iMac MA199LL/early 06
Hi everybody!
My name is Jim. I want to upgrade my old MA199LL/ 17" early 2006 Imac. I can swap the old hdd with the ssd i bought but, do you think it's possible to add a bracket for two 2,5" drives? I would prefer to keep both the SSD and the HDD inside the computer. As much as i searched online, it is possible to fit the bracket though, the height will reach the limit of the given space. But what about the connections? I saw only one SATA port on the board. How can i connect them both? I even searched for a caddy to change the optical drive with it but, to no avail. I'm waiting for the new screen to arrive - it will take some time to find it's way from the U.S. to Greece - and i hope i'll be able to solve this by then so that, i won't have to open the case again.
Any help would be much appreciated!!!
2条评论
Your systems specs: iMac 17" 1.83 GHz Core 2 Duo (IG)
由 Dan 完成的
Thank you for your reply but my model is MA199LL. https://everymac.com/systems/apple/imac/.... Double checked it with my s/n. Thanks anyway!!!
由 Dimitrios Pantazidis 完成的
