跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
677 个问题 查看全部
Is the glass on the iPhone 8 plus rear camera replaceable?
Is the glass on the rear camera of the iPhone 8 plus replaceable? Do you have to replace the entire glass back or is the small glass protecting the rear camera removable like the iphone 7s plus? thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
Yes it's pretty much the same as the previous gens. Will be difficult to find the lens though :/
Difficult repair however! Super hard to get that factory seal, which just leads to dust and dirt behind the lens which will ruin the camera quality. I would go to apple first to see if they have a reasonable solution for it.
这个答案有帮助吗?
得分 1
1条评论:
do you have any comment about this? it´s possible to get that factory seal??
完成的
添加一条评论
It is replaceable but is hard to replace it.
这个答案有帮助吗?
得分 0
添加一条评论
It is replaceable difficult to remove best way is heat it up and remove it carefully.
这个答案有帮助吗?
得分 0
添加一条评论
To be honest, i didn’t find it that hard. First remove camera from inside. Then heat up the glass en try to poke it with a flat screwdriver. Then try getting all the glass parts out. You can reheat it sometimes (makes it easier). When all the glass is removed, use a cotton bud with some nail polish remover to remove all the glue from before. After that you just need to put in a new glass, and afterwards the camera and the screen again…and done
You should take your time, and be a careful but it’s okay to do!
I hope I could help
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jimmy P 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 5,372
