跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2687 个问题 查看全部
Microphone problems after replacing lightning flex cable
Everything went smooth while replacing the flex cable, however something weird is happening now. When recording a video everything works fine, but when recording a video on Instagram or Dictafone you can only hear a static noise and no sound recorded.
Any idea of what the problem might be?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
There are two microphones on the lightning flex cable assembly. Perhaps they were damaged in the process of replacing or simply defective to begin with. They are on two small tabs that each mount on either side of the lightning jack. Check the ribbon for damage like scratches, tears or nicks.
这个答案有帮助吗?
得分 0
3条评论:
Would it still work fine while on a call or making a video through the Camera app anyway?
完成的
Possibly and especially if the issue resides with the apps and not the micorphone. If your in call mike is working and the "Hey Siri" is working then I'd start checking the apps. Maybe uninstall and reinstall Instagram and also look at the microphone permissions in your settings.
完成的
I've tried uninstalling and checking the microphone permissions and still did not work. While on a call mic usually works, I wouldn't say it's perfect but it works. I have noticed there's a red dot which looks like a water damage indicator (I'm not sure) but it is on top of the battery. I purchased this phone second hand, do you think that might be causing the issue? Because the volume down button is not working too.
完成的
添加一条评论
添加你的答案
kraki 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 99
