跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2261 个问题 查看全部
Lines across screen during use following screen change
Hello,
Can anyone help me... ive changed the screen and this is what I am getting... screen seems to die after a few minutes... connectors are on properly... I’m thinking faulty screen
https://youtu.be/gQPriGecD1o
TIA
Rob
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hey Rob! That's quite the odd behavior! Usually that's a sign of the LCD connection being faulty, even if it's seated properly. I'd check the pins in the connections, both device side and display side. The thing to check for is dust/debris in the connection or bent pins. If everything looks pristine, and the device still behaves strangely, then I'd say it's an LCD issue deeper in the display, and you should seek replacement. Best of luck with your repair!
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Rob Bear 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 34
