跳转到主内容
修复你的物品
维修的权力
商店
型号:A1419/ 2012/2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 专业版
306 个问题 查看全部
iMac is not booting (black screen, no chime)
Hello Mac Experts (@mayer, @danj , @reecee and others)
I have an iMac 27", Late 2012 that is not booting properly. It is usually just a black screen with no chime although the fan spins and the first two diagnostic LED's light up. Occasionally, the boot process does happen and I get a white/gray screen then nothing else happens. On rare occasions it will start the progress bar but it has never completed the boot process.
There is also a vertical line, pretty much in the centre, of off-colour pixels (~ 5-10 pixels wide). I'm assuming it is LCD related as the connector looks fine.
The customer originally thought it was the power supply and had ordered one to install himself. Time constraints were such that he dropped it off at the shop so that I could install it.
So here is what I have tried:
  • SMC and NVRAM reset (just to be sure)
  • Checked diagnostic LED's, first 2 are on when I press the power button (note- when it did occasionally start the boot process, all 4 would light up)
  • Installed new power supply, no difference
  • Removed motherboard, re-seated RAM modules, removed CR2032 battery and re-installed.
  • Visual inspection of motherboard, no anomalies found
  • Removed SSD (as part of Fusion Drive) and installed known good HDD with bootable MacOS in place of existing HDD
At that point, the computer started the boot process, chimed and I pressed D to run the Hardware Test. It went into test mode and started the test but froze about 1/3 of the way through and just hung. After another re-start, just a black screen once again with no chime but spinning fan.
At this point, I have to assume it is motherboard issue. I'll start probing but wanted to see if anyone had any ideas.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个回答
已选择的解决方案
Sounds like a GPU issue, plagues the 27" models. Not worth repair IMO; you can only buy these used for a lot of money, and you can't guarantee how long they will last. Bar down the screen could be GPU related if it looks distorted, or the LCD could be bad also
这个答案有帮助吗?
得分 3
评论:
Thanks Reece, I was afraid of that.
完成的
添加一条评论
添加你的答案
Minho 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 20
总计 2,774
