跳转到主内容
初代iPhone(又称iPhone 2G)。型号为 A1203,存储容量有4GB、8GB、16GB可选,机身颜色仅有黑色搭配金属铝。维修初代iPhone是容易的,需要耐心,一些工具和焊接技术。
224 个问题 查看全部
My iPhone 1st generation does not charge
Hi, I recently bought an iPhone 1st gen from eBay. It worked fine for a few months but now when I plug it in it says charging please wait, and after a bit it boots up. After arriving at the home screen, it says low battery and does not charge any further, and it loops in that way continuously.
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
more than likely either needs a new battery or charge port as its an old phone
这个答案有帮助吗?
得分 1
添加一条评论
It looks like this may be a similar issue? My iPhone 2g is not turning on or charging
Try a hard reset "holding home and power buttons whilst plugged into a power outlet" then try cleaning contacts. If that doesn't work you may need to replace the battery.
This answer also suggests simply trying another charging cord wont turn on or charge
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Luca 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 799
